Gå til produktinformation
1 af 5
Aim MXS 1.3 Strada TFT Car Dash Display with Road Icons
SKU: MXS-S-I-OBDII
Normal pris
£1,000.00
Normal pris
Udsalgspris
£1,000.00
Aim MXS 1.3 Strada 5" TFT Dash Display with Road Icons
The MXS Strada with Road Icons is one of the most widely used dash displays on roads around the world.
MXS 1.3 Strada Key Features
Compact 5" Display
Range Of Data Sources
Integrated Shift Light Array
1,000+ Industry-Leading ECUs
High-Contrast TFT Display
GPS09 Module (Optional)
6 Configurable RGB LEDs
Freely Configurable Pages
Flexible Alarms
8 Analogue Inputs
CAN Output
Configure Data
Why Choose The MXS 1.3 Strada Car Dash Display With Road Icons
The MXS 1.3 Strada is available with a choice of connection. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXS 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the car's ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.
Digital Outputs
With CAN output, you can send messages directly to an existing  CAN network to improve the range of vehicle control possibilities.
Pre-Configured Pages
Flexible Shift Light & Alarms
The ten multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or flashing one and the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.
Camera Inputs
Two analogue camera inputs are available to switch your display into a mirror camera, through a pushbutton command or event management. The camera is sold separately.
Pin Harness
The MXS 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the car's ECU using the OBDII port or directly to the ECU through the CAN channel.
With Race Studio 3, you can also analyse all data recorded by MXS Strada and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Compact 5" Display
Flexible Alarms
8 Analogue Inputs
CAN Output
Configure Data
Digital Outputs
Camera Inputs
Pin Harness
  • Display : 5" TFT
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Dimensions: 169.4 x 4 x 97 x 23mm
  • Weight: 480g
What's In The Box
  • MXS Strada 1.2
  • 14 Pin Standard Wiring
  • Aim Sticker
