Gå til produktinformation
1 af 5
AiM MXG 1.3 Strada 7" TFT Dash Display with Road Icons
SKU: MXG-S-I-OBDII-XA8MXGST12I020
Normal pris
£1,250.00
Normal pris
Udsalgspris
£1,250.00
The MXG 1.3 Strada features a 7" wide colour dash display offering great visual impact, and configurable to show data coming from your vehicles ECU.
7" TFT display 8 alarm RGB LEDs
CAN output Configure data
The MXG 1.3 Strada features a 7" wide colour TFT display, offering a great visual impact. It is configurable to show data coming from the ECU. Eight analogue inputs, 6 digital inputs, pre-defined math channels, a second CAN and an optional GPS Module.
The MXG 1.3 Strada is available with a choice of connection. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the vehicles ECU or OBDII port or directly to the ECU through the CAN channel.
Connecting the MXG 1.3 Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is 1000+ and is constantly being updated and upgraded.
Digital Outputs
The MXG 1.3 features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground). They can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems. For example, switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
The MXG 1.3 Strada has a 7" high contrast TFT display. The visual quality is kept optimised by the ambient light sensor which keeps he backlight to its best brightness levels, so as to avoid the screen dazzling you while driving in the dark.
Pre-configured Pages
The MXG 1.3 Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can custom pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy just use the pushbuttons.
Flexible Shift Light & Alarms
Camera Inputs
Pin Harness
The MXG 1.3 Strada has a choice of ECU connection. Choose between the OBDII or K-Line CAN. Depending on whether you want to connect to the vehicles ECU using the OBDII port or directly to the ECU through the CAN channel.
These are only some of the items that can be added to our MXG 1.3 Strada for incrementing the performance and the data acquired.
With Race Studio 3 you can also analyse all data recorded by MXG Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
Digital Outputs
Camera Inputs
Pin Harness
  • Display: 7" TFT
  • Contrast: 1000:1
  • CAN Connections: 2
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Dimensions: 237 X 127.6 X 26mm
  • Weight: 950g
  • MXG 1.3 Strada
  • 14 Pin Standard Wiring
