Gå til produktinformation
1 af 2
AiM Formula Steering Wheel Paddle Shift Kit
SKU: FSW3-PSK
Normal pris
£230.00
Normal pris
Udsalgspris
£230.00
Formula Steering Wheel Paddle Shift Kit.
The formula steering wheel paddle kit has been designed to fit the AiM formula steering wheel 3.
Key Features:
  • Fits formula steering wheel 3
  • Allows for paddle gear shift
Paddle Shift Kit.
Formula Shift Paddle Kit
The Formula Steering Wheel Paddle Shift Kit has been designed to fit the AiM Formula Steering Wheel 3. It allows you to add the paddle shifting capability to the standard wheel.
    • Two Paddle Shifts
    • Four Screws
    • Two Seals
    User Guide
    Technical sheet
    Key Features:
    Paddle Shift Kit.
      What's In The Box
      • Two Paddle Shifts
      • Four Screws
      • Two Seals
      User Guide
      Technical sheet
