Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim EVO5 37 Pin Deutsch Harness - AimShop.com
    EVO5-H37
    På lager, klar til afsendelse
    £385.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £385.00
    The Aim EVO5 37 pin Deutsch harness is the standard harness that is supplied with the EVO5 Data Logger.
    Suitable for EVO5 Standard 37 harness
     4 analogue channels
     37 pin Harness for EVO5
    The Aim 37 pin Deutsch harness for the EVO5 is the standard harness that is supplied with the EVO5.
    The standard 37 pin harness that comes with the EVO5 allows 4 inputs. If you would like to add more inputs to your race data then add this optional harness.
    Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
    • Non-ended cables - See table in Downloads Tab
    • EVO5 37 Pin Deutsch Harness
    Technical sheet Race Studio 3
    • Opdater siden
    • Åbn i et nyt vindue
