AiM 37 Pin Motorcycle Deutsch Harness MXS, MXP, MXG, MXL2, MXM
SKU: H37-V02573010
- Normal pris
- £375.00
- Normal pris
- Udsalgspris
- £375.00
- Pris per stk
- om
The AiM 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.
Suitable for MXS, MXP, MXG, and MXL2. MXm | Standard harness |
37 pin harness | |
37 pin Harness for the MX Series
The AiM 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG, MXm.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.
- 37 pin Deutsch Female Flying Connector
- 5 pins Binder 712 Female Connector - See table in Downloads Tab
- 7 none ended cables - See table in Downloads Tab
- 37 pin Deutsch Harness
The AiM 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.Key Features :
37 pin harness | |
The AiM 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG, MXm.This harness can be used to replace a damaged harness or for a second vehicle installation when sharing a dash logger.
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
