AiM 37 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2, Mxm Motorcycle
SKU: H37-DT-V02573050-MC
- Normal pris
- £375.00
- Normal pris
- Udsalgspris
- £375.00
- Pris per stk
- om
The AiM 37 pin Deutsch harness with two thermocouple connectors to connect K-Line type sensors.
Suitable for MXS, MXP, MXG, and MXL2. MXm | Digital output |
37 pin harness | Two thermocouple connectors |
37 pin Harness with Two Thermocouple Connectors for the MX Series
The AiM 37 pins harness has been designed with two thermocouple connectors, this will enable you to connect two different thermocouple sensors to your device.
Thermocouple sensors available are Exhaust Gas Temperature Sensor, Water/Oil M5 Sensor, Water/Oil M10 Sensor, and many more depending on the application.
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with one or two thermocouple connectors and will enable you to connect thermocouple sensors.
- 37 pin Deutsch Female Flying Connector
- 5 pins Binder 712 Female Connector - See table in Downloads Tab
- 7 none ended cables - See table in Downloads Tab
- Two Thermocouple Connectors - See table in Downloads Tab
- 37 pin Deutsch Harness with Two Thermocouple Connectors
The AiM 37 pin Deutsch harness with two thermocouple connectors to connect K-Line type sensors.Key Features :
The AiM 37 pins harness has been designed with two thermocouple connectors, this will enable you to connect two different thermocouple sensors to your device.Thermocouple sensors available are Exhaust Gas Temperature Sensor, Water/Oil M5 Sensor, Water/Oil M10 Sensor, and many more depending on the application.
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
