SmartyCam 3 GP
SKU: SM3-GP
- £1,500.00
- £1,500.00
Mount Anywhere, Stream Anytime
The all-NEW SmartyCam 3 GP camera has been designed for motorsport with a single purpose:
To provide great videos and supply you with all the information you need.
SmartyCam 3 GP camera overlays all the data from both GPS and AiM loggers connected to your ECU. Full HD camera system, Video output, CAN connection, USB-C connection, and GPS port are only a few of the features of SmartyCam 3 GP: the power of simplicity.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-01.png?v=1677660931)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/RSA3ScreenVideo2023.png?v=1676462761)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-02.png?v=1677660963)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-03.png?v=1677661011)
The SmartyCam 3 GP includes a global shutter CMOS sensor and a low distortion lens with a field of view of 67°, 84° or 120° covering all areas, its lightweight 200g (battery included) framework infallible in providing you with smooth and effortless footage.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Screenshot2023-02-10at14.50.21.png?v=1676041015)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-04.png?v=1677661037)
The SmartyCam 3 GP contains a rechargeable lithium battery confined inside its (main) 120.8x80.2x30.9mm (bullet) 24diamx48.2mm body, and using its connectors - 2 Binder 712 female connectors + 2 SMA female connectors (see pinout page) + 1 USB-C - slots right into the back of your dashboard.
Finished with a sleek anodised aluminium coat, the SmartyCam 3 GP is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 GP has the ability to mount onto many aspects of your vehicle for easier accessibility. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCamGPWithBulletsonMounts_Compressed.png?v=1677596688)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3FeaturesIcons-05.png?v=1677661082)
SD cards sold separately.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/SmartyCam3GP-Officialphoto6_2T_Cropped.jpg?v=1677599342)
The SmartyCam 3 GP can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Connectors: 2 Binder 712 female connectors + 2 SMA female connector (see pinout page) + 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Dimensions: Main unit 120.8 x 80.2 x 30.9 mm | Bullet camera 24 diam x 46.0 mm (120° lens) | Bullet camera 24 diam x 41.0 mm (67°-84° lens
- Bullet Cable Length: From 0.5 m to 4 m (7 lengths available)
- Weight: Main Body - 320g, Bullet Camera - 45g
![smarty cam 3 sport connectors](https://cdn.shopify.com/s/files/1/0214/9392/files/microphoneConnectorsOnSmartcam.png?v=1697445584)
- SmartyCam 3 GP
USB-C Cable
712 5 Pin Male
2 or 4 Metre Can Cable
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Screenshot2023-02-10at14.50.30.png?v=1676282491)
Technical Specifications
- Video Out: 3G-SDI
Whats in The Box
- SmartyCam 3 GP
USB-C Cable
712 5 Pin Male
![SmartyCam 3 GP - AimShop.com](http://www.aimshop.com/cdn/shop/products/bike_set_sc3_track_day_kit-02_720_1445x.png?v=1678895577)
![SmartyCam 3 GP - AimShop.com](http://www.aimshop.com/cdn/shop/products/smartycam3gp_1445x.png?v=1678895577)
![SmartyCam 3 GP - AimShop.com](http://www.aimshop.com/cdn/shop/products/1_19966732-9b54-4778-8149-5841878c146d_1445x.png?v=1678895577)
![SmartyCam 3 GP - AimShop.com](http://www.aimshop.com/cdn/shop/products/2_f1aa3464-0507-426d-b0f5-f903ee43085d_1445x.png?v=1678895577)
![SmartyCam 3 GP - AimShop.com](http://www.aimshop.com/cdn/shop/products/3_128edf2d-254b-4f09-aecd-0736e67eb607_1445x.png?v=1678895577)
