Yamaha YZF-R1 (2009-2014) AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: YAM-3-PP-YAM-2-B
- £125.00
- £125.00
- لكل
The AiM Yamaha motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Yamaha cable & bracket | 7 pin - 712 male binder connection |
Yamaha Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Yamaha YZF-R1 (YEC included) - 2004-2014 | |
Example data protocols
- Specifically designed Yamaha Plug & play cable and bracket for the Solo 2 DL
- Below is the pinout drawing for the Yamaha plug & play connection cable.
- Yamaha plug & play connection cable
- 1 bracket
- 2 spacers
- 2 self-locking nuts M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers M4
- 2 Allen screws with rounded head M6 x 60mm
The AiM Yamaha motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 (YEC included) - 2004-2014 | |
- 1 bracket
- 2 spacers
- 4 washers M6
- 2 washers M4
