Suzuki GSX-R AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: SUZ-B
- £60.00
- £60.00
- لكل
The AiM Suzuki motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Suzuki bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Suzuki Solo 2 & Solo 2 DL Bracket
The Suzuki GSX-R bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.
Please Note: See below to check the bracket is compatible with your bike.
Also available is our Suzuki plug & play cable for the following bike models: (Sold Separately)
GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
GSX-R1000 - 2005-2019 | GSX-R1300 Hayabusa Gen.2 - 2008-2016 |
GSX-R1000 L7 - 2017 onwards |
The Solo 2 & Solo 2 DL installation brackets are available for the following bike models/years:
GSX-R600 - 2001-2019 | GSX-R750 - 2001-2019 |
GSX-R1000 - 2001-2004 and 2009-2019 |
Please Note: Not all product combinations are possible. Solo 2 DL installation brackets are not available for Suzuki GSX-R 1000 from 2005-2008, or GSX-R 1300 Hayabusa.2 from 2008-2016. Please contact one of the AiM support team for further information.
Example data protocols
- Specifically designed Suzuki bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
The AiM Suzuki motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Suzuki GSX-R bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Suzuki plug & play cable for the following bike models: (Sold Separately)GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
- 1 Bracket
- 1 toothed washer
- 1 rubber dowel
