Skoda Fabia R5 Aim SmartyCam 3 Dual Kit - R5 2015 to 2018 - R5 EVO2 from 2019
SKU: SKODA-SM3-D
- £1,480.00
- £1,480.00
- لكل
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Supported Models and years
Skoda Fabia R52015 - 2018
Skoda Fabia R5 EVO2from 2019
These models feature a loom extension supplied by the car manufacturer which has a DTM 4 pin connector on one end carrying CAN and power supply contacts.
Video Output/Streaming
Picture in Picture
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
Quality
Anatomy
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Skoda Fabia R5 drivers
Channels received by AiM devices configured with Skoda Fabia R5 protocol are:
Channel Name | Function |
RPM | Engine speed |
Gear | Selected gear |
Car Speed | Vehicle speed |
AccelPedal | Pedal accelerator ratio |
FrontBrkPress | Front brake pressure |
pHandBrake | Handbrake pressure |
SteeringPos | Steering position Angle |
TripDist2 | Trip distance 2 |
GDUOutLed | GDU output led |
StRoadMode | Status road mode (=1) - Special stage (=0) |
- SmartyCam 3 Dual
- External Power Cable
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
- Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
Picture in Picture
Standalone Feature
Quality
Anatomy
Technical Specifications
- Video Out: 3G-SDI
Skoda Fabia R5 Protocol
What's In The Box
- SmartyCam 3 Dual
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
