تخطي إلى معلومات المنتج
1 من 4
Ducati Multistrada 1200 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-3
£710.00
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati Multistrada 1200 this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Ducati Multistrada 1200 ECU connection cable
This kit has been specifically designed for the Ducati Multistrada 1200 bike. The kit comes with an ECU cable for your bike. Connecting the Solo 2 DL to your Ducati Multistrada 1200 ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati Multistrada bike model:
Multistrada 1200 - 2010-2011
The Ducati Multistrada 1200 ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Ducati Multistrada plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Ducati Multistrada 1200 Connection Cable
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
