Aim Spark Plug Inductive RPM Car Adaptor
SKU: MXL-RPM-IP
- £75.00
- £75.00
- لكل
+ ضريبة القيمة المضافة (المملكة المتحدة فقط)
Spark Plug Inductive RPM Adaptor
The Aim RPM Adaptor has been designed for single cylinder 2 or 4-stroke engines.
Key Features:
The Aim spark RPM adaptor has been designed for installation on single cylinder 2 or 4-stroke engines. It is a filter that converts the RPM signal sampled by induction from the spark plug into a square wave signal. The image below shows the signal sampled by induction on the left and the square wave signal on the right. |
To install the adaptr connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. |
Key Features:
To install the adaptr connect the plastic clip to the spark plug and the cables as follows: The black cable labelled GND to the device GND pin. The red cable is labelled 9-15 VDC to a +12V output (the battery positive pole for example). The blue cable labelled rpm to Aim device RPM input. |
