تخطي إلى معلومات المنتج
1 من 3
AiM SmartyCam GP HD Mini Roll Cage Mount with Clamp 2.1 & 2.2 Motorcycle
SKU: SM-VB-GP-S-MC
£70.00
£70.00
AiM SmartyCam GP HD Mini Roll Cage Mount With Clamp 2.1 & 2.2
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) mini roll cage mount has been designed to hold and position the bullet camera.
Fits the SmartyCam GP HD camera Universal rollbar fitment
Standard or extended length For SmartyCam GP HD 2.1 & 2.2
The AiM mini roll cage mounts have been designed to fit the SmartyCam GP HD bullet camera. This will enable you to mount the camera to a roll bar tube.
The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport.
Provides an easy method of mounting the SmartyCam GO HD camera to a roll cage.
The two jubilee clips allow for fitting to different roll cage tube diameters.
Standard or extended lengths are available.
  • For use with SmartyCam GP HD 2.1 & 2.2
  • Aluminium clamp
  • Two jubilee clips - 44mm & 55mm
Technical sheet Race Studio 3
  • Aluminium clamp
