AiM SmartyCam GP HD Bullet Cam Suction Cup Mount 2.1 & 2.2
SKU: SM-WM-GP
- £80.00
- £80.00
- لكل
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) suction cup mount has been designed to hold and position the bullet camera.
Securely mount to windscreen | For SmartyCam GP HD 2.1 & 2.2 |
The AiM SmartyCam GP HD suction cup mount is for mounting a SmartyCam GP HD 2.1 & 2.2 to your vehicle. The mount has been designed to mount to your windscreen or a flat surface.
The suction cup mount has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
Suction Cup Mount
Securely attaches to your windscreen or flat surface.
- Arm height 60mm ( 2.36 inches)
- Suction Cup
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) suction cup mount has been designed to hold and position the bullet camera.Key Features :
The AiM SmartyCam GP HD suction cup mount is for mounting a SmartyCam GP HD 2.1 & 2.2 to your vehicle. The mount has been designed to mount to your windscreen or a flat surface.The suction cup mount has a unique ball and socket system which has been designed to cope with the rigours of motorsport.
Suction Cup Mount
A solid ball and socket system for optimum positioning.Securely attaches to your windscreen or flat surface.
- Suction Cup
- 60mm arm
- Ball head
