AiM Mychron5 S 2T Patch Lead Double Yellow TC Plugs
SKU: P-712-TC-TC
- £50.00
- £50.00
- لكل
The AiM MyChron5 s 2T (2 Temperature) model MyChron4 and MyChron5. These patch leads are used for connecting different temperature sensors to the dash.
Double Yellow TC plugs | Suitable for fitting EGT, Underplug sensor |
Compatible with MyChron 4 & 5 |
Connects to the three-pin (712) TEMP port on the Mychron dash.
This AiM Double TC Mignon Plug is suitable for fitting an Exhaust Gas Temperature Sensor (EGT) and an Underplug Temperature Sensor or 2 x Exhaust Gas Temperature (EGT) or 2 x Underplug Temperature Sensors.
Cable length 1.5m
- MyChron5 S 2T patch lead with double TC plugs
- Add two water temperature sensors with this patch lead
- Cable length: 1.5m
- MyChron5 S 2T Patch Lead Yellow TC Plugs
The AiM MyChron5 s 2T (2 Temperature) model MyChron4 and MyChron5. These patch leads are used for connecting different temperature sensors to the dash.Key Features :
The AiM MyChron5 s 2T (2 Temperature) model MyChron4 and MyChron5. These patch leads are used for connecting different temperature sensors to the dash.Connects to the three-pin (712) TEMP port on the Mychron dash.
Cable length 1.5m
