تخطي إلى معلومات المنتج
1 من 2
AiM Motocross Suzuki Solo 2 DL Plug & Play Lead
SKU: SUZ-MX-PP
£67.00
£67.00
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Suzuki plug & play cable 7 pin - 712 male binder connection
Suzuki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Suzuki bikes. This plug & play cable can be used for the Solo 2 DL.
RMZ 250cc 4-stroke - 2010-2013 RMZ 450cc 4-stroke - 2008-2013
Example data protocols
  • Below is a pinout drawing for the Suzuki Solo 2 DL plug & play connection cable
  • Suzuki Plug & Play connection cable
