تخطي إلى معلومات المنتج
1 من 3
AiM Magnetic Speed Sensor 712 Plug 1m Cable
SKU: S-S-M712
£70.00
£70.00
Magnetic wheel speed sensor 712 metal connector
1m cable
The AiM non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts required and is available in two versions: a plastic connector (Binder 719) and a metallic connector (Binder 712).
The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field, the electrons move to one side of the metal, and protons move to the other side of the plate. Then you will be able to get a voltage.
The sensor only produces around seven volts. When the electrons move to one side, a potential difference is created between the two sides of the metal.
  • 712 Metal Binder Connector
  • Ensure the distance between the sensor and the magnet is between 8 and 20mm
  • 1 x Magnetic Speed Sensor 712 Metal connector 1m Cable
1m cable
