تخطي إلى معلومات المنتج
1 من 1
AiM Infrared Sensor for Belt Temperature System
SKU: S-IR-SP
£155.00
£155.00
Infrared replacement sensor for the belt temperature system.
Direct replacement sensor Fits infrared belt temperature system
Threaded section & lock nut for fitting 719 4 pin binder
AiM Infrared Sensor
The AiM infrared sensor is a direct replacement for the sensor supplied with the AiM Belt Temperature System.
Ideal for replacing a damaged sensors or it could be used for using the system  on multiple vehicles.
The sensor features a threaded section with a lock nut for secure fastening to a bracket.
Direct replacement sensor for the AiM Infrared Belt Temperature System 719 4 pin binder
AiM Infrared Sensor
AiM Infrared Sensor
Technical Specifications
AiM Infrared Sensor
