تخطي إلى معلومات المنتج
1 من 9
AiM EVO4S Powerboat Racing Data Logger
SKU: EVO4S-PB-GPS-1
£1,180.00
£1,180.00
The EVO4S is a powerful and flexible data logger, offering a wide range of sources for your data. A great tool for point to point racing.
Many options for ECU connection Includes GPS Module
Built-in accelerometer & gyro sensor CAN output
5 fully configurable analogue channels 2-speed inputs
AiM EVO4S Data Logger
The AiM EVO4S is a powerful and flexible data logger and comes equipped with a GPS Module. Offering one connector per channel the EVO4S samples all the information you need, data coming from your powerboat ECU via CAN, RS232 or K-Line, from the internal accelerometers and gyro and the GPS Module included in the kit.
Select which harness you require CAN, RS232 or OBD11, and select which GPS Module best meets your requirements. You can also upgrade your kit with our GS -Dash display and Formula 3 steering wheel, allowing you to really improve your performance while shore racing on tight circuits.
Sensors
4GB memory
RPM input manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
Sensors
4GB memory
  • ECU Connection: CAN, RS232, K-Line
  • External Modules Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
  • Analog Inputs: 5 fully configurable, max 1,000 Hz each
  • Digital Inputs: 2-speed inputs, lap signal, coil RPM input
  • Inertial Platform: Internal 3 axis ±5G accelerometer + 3 axis gyro
  • Internal Memory: 4GB
  • Connectors: 13 Binder connectors
  • Body: Anodized Aluminium
  • LEDs: 1 system staus
  • Dimensions: 130 x 35 x 46.6mm
  • Weight: 330g
  • Waterproof: IP65
    • EVO4S Data Logger
    • Harness of Your Choice
    • Power Cable
    • Download Cable
    • RPM Harness
    • GPS Module
    • Mounting Bracket
